All lights come on as normal on dash, turn key to run , everything is normal. Turn key to start and everything dies. Lights go out, radio resets, like someone has disconnected the battery.
Then, about five minutes later, all poser is back. Still no start, just a repeat of everything dies.
I suspected the immobilizer and would try to reset it and this seemed to work. But all I was doing was killing time and the time allowed the electrical system to come back.
I finally figured out that a fuse must be heating up enough to cause an electrical break. Fuses all tested good, but something was heating up, killing the electrical, then cooling off and letting electrical flow again.
The small fuse box connected to the positive battery pole was the answer. Opened it and removed a 7.5 amp fuse, cleaned the dirty contacts, and everything worked normally again.
I also installed a new main relay thinking this might be the problem. It was not, it was only a dirty fuse.
I had the same problem on a 1978 Volvo years ago. I took out all the fuses, cleaned them, and all was well. I intend to pull all the fuses on this 2000 LX soon and do the same to them.
