I have a brand new battery (2 weeks old) from Costco (24F 700 CCA) and my 97 LX450 didn't start after I left it for a couple days. Thinking it was my son that left a light on or something I jumped it and charged the battery while driving around a bit. After charging the battery, I tested for a parasitic draw (there was none) and I also tested the alternator (bat was going from 12.6v prior to start to 14-15v after start so I believe this means it is working). So after the battery charged I made sure everything was off and nothing drawing on the battery and I left it for 3 days. I come home today and there isnt enough juice to start - all lights come on but voltage reads low and starter just clicks with voltage meter flickering. After 2-3 attempts at starting I got out and checked the voltage on the bat which was 11.5 volts which I understand is too low.
I have almost no electric skills but I have done everything from mud and youtube and none of it is getting me closer to a solution. Here is what I have done so far:
1. New Battery (24F 700 CCA) from costco
2. Checked for parasitic draw - there is none. Method: remove negative bat terminal and test. I was getting 0.2 milli amps at most but most times it was zero. i would also check the draw with a dome light on etc and get 10-20 milli amp readings so i know the test was working.
3. Checked each fuse with multimeter and no showing of a draw with that method either
4. After a jump it will start right up and work for that day on its own. After leaving for 2+ days without driving it will not start.
I am at a loss here given I would think if there is no draw on the battery it should not be losing voltage and therefore start. Any help is much appreciated.
