Cranks but no start. No fuel at fuel filter. Just replaced fuel pump and still no go. Checked voltage coming into fuel pump and it reads 55 volts. Any idea what's going on here? Maybe I need a new relay.
its 2006. I checked multimeter across battery terminals and it was correct.
Do you mean 5.5 volts??? I’m not an electrician but 55v might be enough to blow up your truck.Cranks but no start. No fuel at fuel filter. Just replaced fuel pump and still no go. Checked voltage coming into fuel pump and it reads 55 volts. Any idea what's going on here? Maybe I need a new relay.
Ok this is weird
No Key/Key Inserted/Acc 5 to 6 volts
IGn on 50v
Starting 10.5 volts
Checked fuel filter, no gas
very carefullyI just swopped out Fuel pump- Perhaps I did install wrong. How can I check the new pump without blowing myself up?
That’s one I leave up to the “professionals”I just swopped out Fuel pump- Perhaps I did install wrong. How can I check the new pump without blowing myself up?
