- Joined
- Oct 6, 2016
- Threads
- 26
- Messages
- 312
- Location
- Charlottesville, Virginia
- Website
- www.bradyadventures.com
Strange thing has been happening the last couple weeks. On three occasions the keyless entry has not worked and there is no power at all. Turn the key and there is nothing. I have a dual battery system and if I manually combine the batteries everything turns back on. I am essentially jumping the main battery. On the first two occasions when I combined the batteries the security system went off and I was able to turn it off the honking with the key fob. The third time things just worked again with no alarm. The main battery shows a full charge and after I do this it seems to recover for a day or two. Not really sure if timing is significant or predictable since it’s only happened a few times and it’s not my daily driver. I found a couple threads referencing a fuse under the hood and one in the kick panel that might be the culprit. I didn’t find the exact (by title) fuses mentioned but checked nearly every fuse and they are all good. The ground and all battery connections are solid too.
Any ideas would be greatly appreciated!
