So, I goofed recently and pulled my known good dizzy to verify fire on another motor I have. Once doing that, I promptly put it back into my dd FJ40 and verified spark by starting it.
A couple days ago I used my 40 to move around my car hauler. About 10 minutes total run time. At the end of that task, I glanced down and notice zero oil pressure. All of my gauges work. So I shut here down and removed the valve cover. I noticed metallic bits sitting on top of the head. Started the motor again to see if my gauge was bad from visibly seeing oiling up too though the rocker arm holes. Nothing.
Drop the oil this morning. Tried screening the best I could and only saw minimum metal bits. Talked to a mud guru and friend on the stated symptoms. He told me that i likely did not reseat my dizzy properly. He was right. The dizzy’s clamp at the base of the shaft was warped. 😖 So that’s why I didn’t have oil pressure. Restabbed dizzy, instant oil pressure on the gauge. Unfortunately, I still do not see it oiling at the top. I did pull the oil line from the block and bumped the starter; blew plenty of oil out there.
I’m at a loss on why I haven’t reestablished flow up top. I’m also certain that it’s probably rocker material I’m seeing. Bearings?
Thoughts/suggestions?
