After running my newly rebuilt 71 F motor for its 20 min break in, it's apparent nothing is coming through the oil pipe running through head into the rockers. I fear either the oil passage is clogged or the machine shop may not have properly positioned a cam bearing. I can feed the rockers with an alternate copper oil line, tapped into the discharge of the oil filter housing (currently feeding extra oil pressure gauge), through the rocker cover, into the union connecting the rocker halves. My concern is the cam may not be getting oil at one journal. I've removed the copper oil pipe and snaked it to make sure it's not clogged and it's not. Although the engine didn't run too badly, the rockers were loud which I attributed to adjustment. I couldn't swear the problem didn't pre-exist the rebuild. What do experienced LC builders think or suggest?
