Trying to determine if my front diff and rear diff are the same ratio... no looking good. I have coarse spine up at front pinion flange and turning the wheel gives me a 4.1 ratio at driveshaft.
On the rear, I tried the rotating tire trick but brakes kept sticking and preventing freewheel.
I pulled the diff cover plate and there are no numbers on my ring gear, looked at posts to assure and I'm looking at the right spot. Pushed cruiser up and back 10 feet to assure I'm not missing a section. Has Japanese letters on the side of the gear. I counted the pinion and it has 10 gears. From what I've read 10 gears on the pinion is 3.7... end of story right? There is no way I can have 4.1 on the rear if I have a 10 gear pinion?
Thanks ahead, CD
Thanks ahead, CD
