Alright, so I lost my marker lights a few days ago after some torrential rains. Initially I thought it was dampness in the driver rear quarter, per multiple threads I’d read. But after drying that out it made no difference. Continued to lose fuses after a few seconds to a few minutes of driving. Fast forward to today, when I tried to to take the plugs apart And couldn’t get the biggest one undone because it was so tight going down beneath the body, where it comes out above the bumper. So I looked down there and found a mess. The PO had hacked into the harness there for this thing, whatever the seven hells it is. It was wrapped around the harness multiple times, pulling it tight...
I absolutely loathe those connectors. They suck. I cut and stripped the harness where these were and could see it was corroded badly. So I cleaned them and used weatherproof butt connectors. I will solder them later. This is just to drive around for a week and make sure it’s solved.
This is where it was located, it is directly below the compartment that holds the tire jack, and is outside of the body, even with or slightly above the bumper. It was wedged in that body cut out. Anyone able to shed some info on this? I believe it’s a controller of some sort for a trailer? Not sure.
Thanks all! Michael.
