Preface - 1996 FZJ80 138,xxx miles - I completed a head gasket job recently (<200 miles ago,) so I'm guessing the issue lies with something I disturbed during that project. Full valve job, head studs, OEM gasket set, new plugs/wires/cap/rotor (all OEM.)
When on the highway under little or no load, it has a pretty bad stumble/hesitation (flat ground or slight downhill with cruise control on is when it is the most noticeable.) No CEL, no jumping needle on the tach (or RPM fluctuation on the SGII.) Happens in 3rd or OD, CDL locked or open... Seems to only do it at higher speeds, and only once the engine is warm (closed loop only?) The truck runs good otherwise, idles smooth @ ~650 rpm, timing set to 5-6* BTDC, runs good while under power or decelerating on the highway, power is as expected. Intake hose was replaced with a stainless piece with silicone couplers, so I don't suspect that it is leaking. Sometimes I'm pretty sure I can hear slight backfiring when it is stumbling, which makes me think it is engine related (not VC or torque converter?) O2 sensors are original as far as I know.
I removed and plugged both vacuum hoses from the "T" on top of the EGR valve itself, and the stumble was still there, so I don't think that is the problem (I guess a vacuum leak elsewhere in the EGR system could still be an issue?)
As part of the HG project, I installed a VC120 vapor canister to replace my bunk OEM one, so I wondered if that could be part of it. I plugged the purge line between the canister and the purge solenoid, but the stumble was still there.
I parked next to a good friend with a 94 to compare vacuum routing, and it all matched (except for his extra PAIR system components/plumbing) as far as I could tell without tearing intakes off.
I'm guess it could be wiring after disturbing the harness, but If anyone can think of a place to start based on the symptoms that would be a huge help.
Thoughts?
Thanks in advance.
Thoughts?
Thanks in advance.
