No Leaks Whatsoever
Discussion in '80-Series Tech' started by Underdog, Mar 30, 2004.
  1. Underdog
    Underdog
    57
    1
    Mar 28, 2003
    I'm still amazed at my '94. Bought it a year ago January at 136K and I just rolled over 152K. No leaks anywhere and the engine is immaculate! Drives like new, no rattles sqeaks nothing. Still blows my mind how awesome these things are. This comes to mind b/c I got behind an H2 on the tollway yesterday and you cold tell he had been on one of our whiterock dirt roads so everything was real dirty. His rear diff was covered in oil and you could see where it leaking from around the side. How old could this thing be?
    I'm a True Believer.
  2. landtoy80
    landtoy80
    5,805
    317
    Mar 13, 2003
    North Front Range, CO
    Underdog, You must of got a bad 94 :D The only thing that didn't leak on my 94 was the............................windshield, and that has stone chips in it.
  3. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
    No kidding. I would worry if my Cruisers did not leak. :p
  4. Underdog
    Underdog
    57
    1
    Mar 28, 2003
    I don't have even the slightest leak anywhere although I did replace my valve cover gasket last fall (did all the maintenence items axles, rotors, pads, fluids, plug wires, rotor, plugs at the same time). Nothing was leaking prior to this but I did have weeping birfs and some scrunge around the valve cover. Also put in a brand new windshield about a year ago so no chips (yet)! :)
  5. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    My '93 didn't leak a drop until I rebuilt the motor :mad:. Well, it leaked a few drops of gear lube out of the t-case until I replaced the speedo o-ring.
  6. MoJ
    MoJ Moderator
    3,471
    319
    Oct 24, 2003
    100k, no leaks, knock on wood.
  7. landtoy80
    landtoy80
    5,805
    317
    Mar 13, 2003
    Underdog,MoJ, are you sure you guys have fluid/oil in your rigs. When mine stops leaking, that means that I am out of fluid/oil.
  8. offroadkid
    offroadkid
    978
    Albums:
    1
    41
    Oct 22, 2003
    El Dorado Hills, Ca.
    143K on my 97 and dry as day one!
  9. e9999
    e9999 You want to do what...? Moderator
    16,594
    487
    Sep 21, 2003
    US
    drive train dry as a bone...
    A/C connector a tad wet, though...
    E
  10. concretejungle
    concretejungle SILVER Star
    9,515
    742
    Oct 27, 2003
    North Cadillac
    Engine - no leaks.
    Interior - too many leaks (driver's floorboard wet after hard rain, checked sun-roof drains and they are clean, rear hatch door window small leak, rear passenger door leaks around speaker. . . more to come i'm sure)
