no fuel
It's been about a month since I fired up the cruiser. The engine turned over fine but wasnt starting. lifted the hood and no fuel in the see-thru fuel filter next to the carb. I havent had time to look at it but it seems like maybe the fuel pump? It is basically a mechanical pump right? seems like it would be real hard to kill this pump. any inputs appreciated. yes i do have fuel in the tank.
My mech. fuel pump went out on me a while back. Replaced with a $40 Napa electric. Haven't had any problems, may eventually go back to mechanical, just cause thats the way its supposed to be, and less drain on my battery/alt.
How long did you crank it? If there is no fuel in the lines it may take a little while to fill everything. The pumps do go, however. I had one fail on me, got a new one, and when I got in there to change it, the little spring was just knocked off to the side. It was perfectly good.
