1996 LX 450, 119,000 miles. Everything worked up until 3 months ago. First the cruise control died, next the horn, and last week the rear wiper. First it does leak inside when taken through car wash. Suspect bad seal on sun roof. Next I pulled the wiper apart and found that if I ground it to the chassis with separate wire it works fine. Pulled the airbag off and cannot figure out what makes the connection with the horn is pushed? there is a connector that is not connected to anything. Horns work fine when plugged directly to a 12V source, no voltage getting to the power wire when horn is pushed. Suspect a ground?
