No backup lights. Slips out of reverse.
  • Thread starter kybishop
  • Start date
  • Watchers 2
kybishop
kybishop
Frankfort, Kentucky
Trans feels good engaging in all gears. Reverse feels fine in everyday driving other than a slight delay for it to engage. Shift to reverse then maybe a second goes by then it engages. The only time I noticed it slip out of gear was at the farm backing for a long distance. When I reached a higher speed in reverse it would slip out. Let off gas and engage and go. Only slide out of gear while reversing at a higher speed and goes right back in when letting off gas. It hardly ever happens cause usually do not reverse that fast.
The backup lights do not work at all.
Have read a few threads on here but still not certain of the culprit. Should I start with the connections, wiring and switches to the transmission or the shift linkage adjustments?
Thanks.
kybishop
kybishop
Frankfort, Kentucky
I have not had a chance to try and trouble shoot this but thought I would check in again.
Anyone have any idea where I should start in trying to figure this out?
Thanks.
Offroads4x4
Offroads4x4
SLC, UTAH
I would check two things.
Check the gear selector on the trans to make sure it is adjusted correctly for each gear.
Next adjust your trans shift cable of any slack.
I assume you have checked your fluid to make sure it's full.
gbell210
gbell210
Poulsbo, WA
Is your "R" illuminated in the center of your gauge cluster when you are in reverse? Do any other gear indicator lights not work?
Squash
Squash
Sudbury, Ont. CA
Call me crazy...pull the back up light bulbs, try reverse, reinstall bulbs one at a time all the while trying reverse.
kybishop
kybishop
Frankfort, Kentucky
Crazy...
Yeah, the indicator lights do work in each gear.
Sounds crazy... I'll do it! :beer:
Thanks!
N
Nykies
Austin, Texas
I have the same issue. No reverse lights and jumps out of reverse at high RPMs.
Only difference is that my indicator dash light is inop.
I will keep checking for a solution.
kidglove13
kidglove13
Richmond, VA
I had a similar problem when I first bought my truck
What about trying to play with or adjusting the neutral safety switch on drivers side of tranny
Getting that adjusted fix my problems
kybishop
kybishop
Frankfort, Kentucky
It's getting dark here in central Kentucky right now, but I'm looking at the neutral safety switch first chance I get.
I look forward to thanking you fellas.
Redmon
cc93cruiser
cc93cruiser
CRUZAHEAD
Hayward, Ca.
It's a flat quarter of a clock shaped sensor/switch...located on the driver's side of tranny..
Funner
Funner
Phoenix, AZ
Flat quarter of a clock shape? Please post a picture of which kind of flattened quarter of a clock I should look for:rolleyes::D
jvazquez53
jvazquez53
El Tractor
San Juan Puerto Rico
Website
www.facebook.com
This is it. $165.00 @ Rock Auto. Make sure this is the problem, most electrical parts if not all cannot be returned. I thought mine was bad, since I wasn't sure, I took the truck to the mechanic and that was not the problem. It was a bad ground. Took care of the problem for $75.00:cheers:
Neutral switch
cc93cruiser
cc93cruiser
CRUZAHEAD
Hayward, Ca.
Thanks Jose....
kybishop
kybishop
Frankfort, Kentucky
I was wrong.
I was mistaken. All my gear selection lights were working, I remember looking at my D to see if it had faded any. But, none of them are working now and I am not sure when they quit. Maybe the same time I lost reverse lights.
I checked the 10 amp fuse for the gauge that is on with the reverse lights and the fuse is fine. Tried another just in case it just looked fine but still, no dash gear selection lights in any gear, no backup lights.
kybishop
kybishop
Frankfort, Kentucky
I adjusted the neutral safety switch full extent both ways and didn't notice any difference.
Bad ground or time for a new one? Where do you check the ground on this thing? Does it ground itself to the transmission housing or through the wiring?
I did just discover or correct myself that I do not have any of the dash indicator lights working for the gear selections.
Thanks.
kidglove13
kidglove13
Richmond, VA
You need to adjust the switch in small increments either way it is pretty sensitive is what I have found
Just adjusting the thing full either way is not going to do it
You need to have another person in the truck when you are doing it to get it right with the ebrake on and adjust the switch in very tiny increments as the other person shifts the tranny.
Did you mark the switch before you messed with it?
Try this first before you go and buy a new switch
