Nitro Xtreme Diff covers for Semi Float Landcruiser! Now in stock!
As many of you know the factory stamped diff cover on the Toyota Landcruiser 9.5" semi-float rearend is little to be desired. They are thin, rust easily and dont adequately protect your expensive diff parts from damage. Since these are sort of the oddballs, none of the common sources make a diff cover for them.
The problem has now been address the new Nitro Xtreme Diff cover. Already a staple in the offroading community, the Nitro Xtreme cover is now available for Toyota's only application that utilizes a removable cover. Replace your dented rusty cover with a thick beefy aluminum one.
-Made in USA
-High strength Aluminum will not rust, also helps dissipate heat prolonging differential life.
-Extremely thick, will not dent, Cast gusseting to prevent being crushed in the rocks.
NP COVER-TLC $139
9.5" TOYOTA LAND CRUISER REAR DIFF COVER. FITS SEMI-FLOAT MODELS ONLY.
-USA FJ40, FJ55, FJ60, FJ62, 91-92 FJ80, SOME 93-94 FZJ80
-Some INTL MODEL 40, 55, 60, 62, 70, 80
Available for purchase through Landcruiser shop of your choice. Attached Images
-Made in USA
NP COVER-TLC $139
