Next things I want to do with my rig
Scottsdale, AZ
Sorry I am board so i just wanted to know what people had to do to there trucks before Arkansas or anytime in the future. This is my wish list.
1. Motor mounts, x member for motor
2. work on springs(take leaves out)
3. find oil leak on motor.
4. Clean and check frame for cracks
5. Put air in tires
Long term:
Rebuild truck with 4 link front and rear tube from crowl back.
OK,,,
#6 Replace tires with hawgs....;)
Or pit bulls
or IROKs
Iroks would be your best choice.
I'seen kowboy's & Josh's mold and adhere good to the ground.
I would certainly like to get them tires for my truck!
I'll be calling you later in the year to do a spring over.
5. Put air in tires
Long term:
Alright I have about five minutes but, heres the short list:
Lift it - either OME or if I hit the lottery the Donahoe Racing kit!
Tires- probably go with some 285's BFG-MT's on some steel rims
Working on some ideas for the trailer to make it a bit more usable (as well as finger friendly, ask David G. why on that one!)
CB install
Bumpers, skids, etc. etc., etc.
1. Mount winch
2. Fix springs
3. Manual valve body for the tranny.
4. Go'n to need tires soon. Side walls are cracking.
5. Oh yea, fuel injection.
1. fix the dubla leak
2. get Metal tech cage in (if it shows)
3. remove top
4. fix leak on dubla ( done it 2x allready know it will take more ;) )
5. install 4 points in 4 places cause everyone knows now I cant spot myself through shiat
6. stinger front bar with winch mount... and find a winch
7. paint
more after that but thats what I weant done for Twister
GIIIIIIIIIT-RRRRR-DOOOOOOOOONE BOY!!!! Maybe a couple of wrenchfests will git ya thar.
your more that welcome to come up and see how I treat the other one with a sawsall ;p and even cut some :grinpimp:
allright, so i'll throw in some stuff here...
40-
get the e-brake to release
get the thing running right
fix some o' the electrical mysteries
put in the cage
put on the bikini top
55-
rebuild the engine
put in the 465
new/used tires
then spend an a** load of money from there
60-
rear bumper(already designed, now to get jk to build the thing)
and.. well this is a surprise, so you will all know pretty soon.
buy an 80
buy an fj
buy an fj45(one of each)
buy one of each type of diesel out there
you know, while i'm dreaming....:eek: :rolleyes: :cheers:
