It worked for me, both times (2 trucks.) If your in doubt, show the manifold to the machine shop. Ask them if they can get it flat. The design is very similar to the GM straight 6 so any shop with some experience will have likely done a the job before. The key to having it work well is getting the thickness of the intake and the exhaust under the bolt head the same. That's why its important to have already replaced the gaskets and torqued the bolts connecting the two. If the intake is thicker than the exhaust, under the bolt, then the exhaust doesn't get enough stress to make the seal. When you have it apart definitely check the function of the heat riser valve in the exhaust. In rust prone regions, the shaft will sometimes seize up. Also check the flat part of the intake casting above the heat valve, below the carb for cracks. A stuck heat valve can overheat this area and cause cracks. This makes for a hard to find/repair vacuum leak.
