Newfield Click/Tick
Discussion in '80-Series Tech' started by landtoy80, Feb 15, 2004.
  1. landtoy80
    landtoy80
    5,805
    320
    Mar 13, 2003
    North Front Range, CO
    My Newfields are clicking on full turn in deep snow. I hear a click once in a while when turning sharp but not all the time.
    It is not a pop, its a metallic tick sound.
    It doesn't click on the full rotation of the wheel. Its like only half of the Newfield has the tick as the noise happens at the same place when the wheel turns.
    The noise only happens on half of a rotation. The other half of the rotation there is no noise. It does it on both side but I cant hear the pass. side as well as the driver side.
    I have just started hearing this noise this winter.
    I have under 30,000 mi on them.
    Anyone with Newfields have this problem?
  2. semlin
    semlin discouraged user
    5,246
    Media:
    1
    Albums:
    1
    1,577
    Mar 27, 2003
    north of 49
    Kurt
    Not sure I understand. Do you mean it clicks when you turn the wheel, as distinct from actually making the turn?
    In my experience the click from a birf happens when you are underway during the turn.
  3. landtoy80
    landtoy80
    5,805
    320
    Mar 13, 2003
    If I turn the steering wheel full to the left and drive, I hear the clicking.
    Same for the pass side but the steering wheel is turned to the right.
    It happens when I hold the steering wheel and drive in circles.
  4. Rogue
    Rogue
    969
    2
    Mar 27, 2003
    Jefferson
    [quote author=landtoy80 link=board=2;threadid=11557;start=msg105317#msg105317 date=1076888611]
    [/quote]
    Don't do that and they won't click.
    Buy some new birfs and be ready to get greasy.
  5. landtoy80
    landtoy80
    5,805
    320
    Mar 13, 2003
    I hope they are not wore out at 30,000 mi.
  6. semlin
    5,246
    Media:
    1
    Albums:
    1
    1,577
    Mar 27, 2003
    north of 49
    Kurt,
    I think I understand you. It sounds like you have wear in one place on the birf. I have something similar.
    I have 10k on a rebuilt oem birf with about 1500 miles since a repack. I am about to pull and replace it. It pops/clicks on a turn when moving about halfway through the turn, particularly on a left turn. About 4 or 5 rapid pops. It won't make any sound if I turn the wheel to full lock while stationary.
    I have also noticed I get the noise more on a wider axis turn. If I turn tight right or left into the nearest perpendicular lane (e.g., a normal sharp right turn or left turn into a one way street) I usually get no noise. If I make a normal left turn across one lane, or if I turn wide right straight into the passing lane, I tend to get the noise.
  7. e9999
    e9999 You want to do what...? Moderator
    16,629
    513
    Sep 21, 2003
    US
    oooolala!
    Birf attack time!
    :D
    E
  8. Bradass80
    Bradass80
    220
    Jul 24, 2003
    Colorado
    Wasn't there a rumor a while back that cv unlimited was having this problem with all of their birfs, and that they were easily breaking?
  9. Junk
    Junk
    6,177
    29
    Dec 13, 2002
    buggerville nj
    LandToy, No offense, but shouldn't you expect that since that's what is in there? There is a trade-off with after market birfs.
  10. Big_Moose
    Big_Moose
    426
    Aug 26, 2002
    LandToy
    Here is the reason your newfileds are clicking!
    The larger wear spot is the drive side of the birfield inner star, while the smaller worn section is the coast / reverse side of the birfield.
    When the Birf is turned the ball gets stuck / caught / pinched between the wear spots and the corresponding wear mark in the birfield cut & inner cage
    Pics:
  11. Big_Moose
    Big_Moose
    426
    Aug 26, 2002
    Picture 2:
  12. Big_Moose
    Big_Moose
    426
    Aug 26, 2002
    Picture 3:
    You will have to examine the newfield to see how much wear is present. If it is really worn, then there is the chance that the pinched / bound ball will break the inner cage!
    Joe
  13. bjowett
    bjowett
    3,682
    1,383
    Oct 28, 2002
    Western Massachusetts
    Yowsa... don't care for that kind of wear on what should be a stronger and longer lasting part! Material problem! Also, what type of grease did you use with that? I read an article years back about Porsche 930 Turbo race cars wearing out CV joints... until they switched to some super expensive grease. It is used for bearings and such in very high heat steel smelting/processing equipment. Crazy expensive, but if it does the job....
    FYI, 86 - 92 Supra outer CV joints are a great source for inner parts. The outer bell/cup is different due to the semi floating design, but all the internals will swap into an 80 cup.
  14. concretejungle
    concretejungle SILVER Star
    9,551
    760
    Oct 27, 2003
    North Cadillac
    It has been my understanding based on info provided from this board, that when you get the birf's strengthened the process actually makes the metal softer which allows it to wear more quickly but at the same time keeps them from snapping as quickly. The 80 being full-time 4wd means it wears them out faster than stock.
  15. bad_religion_au
    bad_religion_au
    2,213
    2
    Apr 24, 2003
    but aren't newfields made to last longer (ie less ductile)?
  16. landtoy80
    landtoy80
    5,805
    320
    Mar 13, 2003
    Warthog,is that Newfields or OEM birfields? My OEM ones with 208k mi looked like that.
    I got a E-mail from CVUnlimited
    "KURT, I AM NOT SURE WHAT THE PROBLEM IS IF IT IS THE NEWFIELDS IT WILL GET
    WORSE AS IT WEARS MORE. IF IT GET TO THE POINT YOU WANT TO CHANGE THEM WE
    WILL GLADLY REPLACE THEM AS LONG AS THEY ARE BAD.
    THANKS
    GEORGE STUCKEY"
    I will,when it gets warm out, pull one and see what it looks like.
