Newbie-Would a 91 FJ80 Make a Good Huntin' Truck???
I’ve been looking for a Toyota pick-up for a huntin’ truck when I came across a 1991 Land Cruiser. Seats are a little ripped. Center console has screw holes in it. Dash is a little worn out. The out side has some scrapes and dings, but from 15’ it looks good. It’s in perfect shape to drag out in the woods and not worry about getting mud in it or the paint scratched.
Anything I should look for, or look out for with this particular year/model? When a drive it and inspect it, any advice for things to check thoroughly? I’ve read about the locking front diff. I’ll look for the magic K294 = Lockers. Is that marking found on the 91’s? He’s asking $3,000 for it, so I’m not planning on paying more that $2,500.
My plans are to add a roof rack, a 3” body lift and through some 33 or 34x10 swampers under it. Pull the carpet out and all the interior parts from behind the rear seats. Through some KC lights on the front and head into the woods!
Is a Land Cruiser the right vehicle to do this with? My other thought would be a 4-Runner. I like the fact of having a back seat for other people or items (guns, bags, ect).
Late
R
Mine works good for a hunting rig. Matter of fact, ive got a 2.5" and 33 inch swampers.
You wont find lockers on a pre 93 80 unless they are aftermarket. Youll find the center difflock switch though.
Keep in mind, with an SUV you smell what you kill. Unless you put one of those departure angle killing racks on the back. I thought about building a plastic box of sorts that comes about half way up....say to the top of the rear seats or so, and then pulling some rubber seals on the tailgate so I could slide game into it and when I close the tailgate it seals it in. Too lazy though.
Welcome to the board. Let me be the first to give you the official salute :flipoff2:
Now that the pleasantries are out of the way... Check out the newbie guide for differences in years.
To save you from reading, the 91-92 models do not have fr/rr lockers and have the engine out of the 62 series. I'm pretty sure it's a 4.2 L pushrod straight six. Not powerful and very bad on gas. I do think that it's a good bush truck.
hi
91 does not have lockers.only center differential lock.how many miles?does he have documentation for previous service work performed?read up on birf maintainence on search.you must find out what work has been done to it or you could spend several thousand more on parts.if no service records i would only give $2000.:beer:
LateR, my LC is not my DD . I use it primarily as my hunting rig. It's the best hunting truck I've ever owned, and I've owned a lot of em'. Go for it you will not be sorry.
better not be huntin anything very fast. ;) Welcome :flipoff2:
For 2500 I think you'd have a heck of a hunting truck.
The 3FE engine in the 91 is, according to many, somewhat underpowered for the rig. It's pretty slow in city and highway driving.
Offroad, you should have no problems with it. Lot of torque in that 3FE.
For $2,500, I think you'll be getting a hell of a rig. I'd do it.
I'd suggest a swap of just the springs and shocks from what's on there now to somethink like an Old Man Emu 2.5" spring/shock combo. A body lift is not what you need if you're only planning on running 34s.
No optional FR/RR lockers, so don't bother looking for the code.
I own both an FZJ80 and an '89 4Rnr (w/removable shell) and IMHO, the 4Rnr is too small to carry any large deer/small elk/pink flamingos :flamingo: with all the added gear you'll be carrying.
Go for the LC. My $0.02.
WET
YES.
It would make a great hunting truck.
You might consider a coil spring lift rather than the body lift. If you'll be loaded up heavy you can get a system designed to accomodate the extra weight. You'll get a lot of folks telling you that the 91-92 models are underpowered. Having owned a 91 I didn't see it as a problem, especially not for a hunting truck. The 3FE 4.0L engine is known to be very reliable. If it's mechanically solid, that's a very fair price.
Go for it at that price. You can run 33s with no lift or buy an entire suspension for around $700. The only downfall I can see is width of the truck if your hunting trails are tight.
Thank you all for the great info. I’m not worried about power but that’s a great point. What would be the most costly thing to replace? I would hate to get into a money pit. Engine, Tranny, ect.???? Is the LC more costly to maintain that say a 91 Toyota pick-up????
And any specifics to look for when inspecting the truck. I’ll traveling 3 1/2 hrs away to look at it. I have other business to do in the area…hunting…lol, so its not out of my way but I wont be able to take it to a shop. It’ll just be myself and a couple buddies.
The front axle is the main thing that has likely been neglected. Since these are AWD the front axle sees a lot more use than a normal Toyota truck. Its only about $250 in parts to redo it yourself unless the birfields are shot. I would look for excess weeping around the wiper seals and listen for clicking from the front end while turning.
Later,
No the 3FE will turn the 33" tires fine for low range work and off orad duty. I have had mine set up with the Old Man Emu 2.5" springs for 3 years now and love it. Check out the front axle on it for sure.
as to your question of money pit stattus, The mini truck will be cheaper to run in the long run due to the availability of used parts, But the 3Fe and a440 trans on the 91's are a pretty bullet proof set up.
JMHO
Dave,
with 203k on the clock.
I have a '95 that is used as my guide rig. I am hunting and fishing out of it all the time. Mine was super clean so the first brush scratches down the side hurt:princess: , for about 10 seconds. I have carried 18 FB, 12 shells, 12 floater goose :flamingo: and 24 duck floaters and my dog in a kennel and all the other hunting crap in one trip. My hunting partner couldn't believe it. It also swallowed a cow elk a week ago. Yes you will smell it if you put it inside. I use a tarp to protect the interior.
Put some good tires on it and it is unstopable! 6,000 lbs provides alot of traction.:grinpimp:
Fly Rod
Gas.
Seriously, putt-putting around the woods looking for Bambi will give you pretty horrible mileage, but these are sweet rigs. Nothing else that would do the job remotely as well gets significantly better mileage anyway, so not really a big deal.
I have a '95, and it has significantly more power than my buddy's old '91, but like you said, that might not be a big deal to you. His was great for many, many fishing trips and he has missed it since the day he sold it. It was just too much of a dog pulling a boat and the mileage was killing him as a DD.
If you can live with those two limitations, $2500 for the rig is a good deal. Lockers are nice on the newer rigs, but you could put a locker in the rearend and be way ahead money wise with the '91.
I have found my LX450 to be just ok at hunting.
Squirrels and small game are easy to hit, but its hard to keep up with the deer on the trail...
