Hello,
I'm a newbie at diesels and not a mechanic. I'm considering buying a used landcruiser with a toyota 3b diesel engine. The truck is in oregon. The owner said that it would need new fuel injectors. I don't know if the guy is correct about this since I'm not a mechanic...but here is what he said: "the truck smokes when you start it cold. It smokes a a lot and has gotten worse since last winter. It DOES NOT smoke when running. I believe one of the injector nozzles is leaking into the cylinder when the eng is off. This will cause the condition I am having. It clears up very quickly and has not effected the running of the truck or MPG."
Does this sound like a reasonable assessment? and what would it cost to fix this if it was the injector? Are the parts available?
The car was his daily driver and didn't sit around much. I don't know how many total miles it has.
thanks for your time
Ben
Ben
