Build Newbie and his "restored" basket case 1972 FJ45
More refined, but also has a significantly lower 1st gear. 4th is the same as 3rd as far as 1:1, but you'll need MUCH less clutch work to get 33s turning with an H42 (or, better, H41) than you will with a J30.
You could look around your area for someone swapping a V8 and buy the 2F/H42 complete to save yourself some trouble.
Thats a really valid point too, tbh I am worried there may be a cracked cylinder or cylinders, being from Ecuador I assume they had water in the block, then while it was here in CT froze, and pushed out some freeze plugs... even if the freeze plugs did do there job, there is still a chance.
The information provided by a dry then wet compression test is well worth the price of a starter IMHO. Got any local cruiser folks you could borrow their spare.
In your case, borrow the leak down test stuff from the local big box parts place and see if it does hold pressure in all jugs Yes get a starter and do a proper compression tests dry/wet. No well I would tear it down as the next step.
As I voiced to my landlord last night,
I am mechanically capable, I essentially rebuilt about 60% of my 2uz in my GX470 in chassis, no issues, after some systemic diagnosing of a minute headgasket leak. I've rebuilt known good engines, spent 10 years as a heavy equipment mechanic, etc...
This though is the first time ive undertaken a project this size where the vehicle is completely disassembled, so I apologize for some of the newb questions, I do try to read as much as I can before inquiring.
Thanks for the tips, I will take this advice and put it to use.
no way they didn't let you crank it up before you bought it?
I'd get a USA front bumper (with no bumperettes or holes for them) so no one else knows you got a SA import
I actually bought this sight unseen, knowing that I would have to dive in to at least something lol , it was sold as non-running.
plenty of new OEM reman starters in stock here with the correct hardware. They're actually less money then the parts store ones even if you don't have a core. I would just see if you can get it running at all before spending any time doing any real diagnostics. You already know you are going to have to work on it with the freeze plugs and such so I wouldn't spend a ton of time on that long block. Complete good 2F's are easy enough to find that it isn't really worth the time to mess with 1F/1.5F stuff too much if it isn't a concourse resto.
I am in Woodstock Connecticut, north eastern corner. I picked this up in Kent/Cornwall Bridge.
Thanks for the heads up on the local clubs, I hope to be cruising around come spring 2027!
We're not that far apart. I'm in central CT and eastern NY depending on business. If you need anything I might be able to help. 3 FJ40's in and still learing;-)
I greatly appreciate that!
I do have a starter and hardware on the way to do a compression test on my 1.5f , I also have had talks with another member here about picking up a nice 4 speed setup.. so that solves one of my problems that I am very excited about.
I wont talk about the many thoughts I have in my head should the compression test go poorly hahaha, it's been non stop thinking about it.... I'll let one thing happen at a time.
Us spec fj60 should have 3.73 gearing correct?
Picking up the 4 speed sunday, have time tomorrow to grab a set of fj60 axles pretty local to me in good shape for my front disc swap but if its running 3.73s thats perfect as I had thoughts of 3.70 gearing for a little lower rpm at cruising speeds.
Took a 90 minute one way trip to pick up this low mileage rebuilt 4 speed with a twin stick setup, dont know much about dual stick setups but it has a "cool factor" .... i will have to research more about it as well as if I need any additional parts.
Not necessary for me but this was a good buy from a member here and im digging it
I also have dog of the blue variant
I have a good feeling going into this compression test. It turns over very easy and I peeled off the goop on the freeze plugs and it APPEARS they were just covering up some pin holes in the plugs themselves, none of them had been pushed out which gives me hope that it wasn't what I first suspected.
I also popped the valve cover off and its very clean aside some surface crud on top of the caps from sitting for 2 years
Nothing wild to update with but I did put together a setup for my compression test, and I know, I know, not a toyota reman starter, after the CR test I am just going to have it on stand by as a spare. I had some rewards points to use up and ended up with it for $5 delivered.
Will do a compression test this weekend, I don't get home till dark this time of year so the actual test will have to wait.
I also saw a boss bags setup show up less the air supply portion of it in classifieds and snagged them to add to the build.
Ive made a couple changes to what I want to do the more I research and dig in.
I really like the stance of the truck now so I am going to run my leafs but upgrade to OME shackles, pins, etc as well as OME or Bilstein shocks, haven't decided yet.
The tires on it now I also am pretty fond of, they measure out at 32s, and the price is appealing should I need to replace them.
On the trans/transfer...ditch the twin stick..buy a normal shifter also ditch the crossmember..those things love to crack aluminum cases you can hang all that off the bellhousing
You have a starter. But, if you spin it without a distributor, then you have to find TDC of the power stroke/firing stroke on piston #1 when you reinstall the distributor. If you spin it without a distributor, then you'll want someone to spin the oil pump while the starter is cranking. Running the engine without oil pressure will ruin bearings almost immediately.
I'd not worry about compression, yet. Is that rust on the rocker assembly? I would start by doing an oil and filter change, looking for any sign of coolant or water in the oil. Inspecting and cleaning the PCV valve. You'll eventually have to clean the rocker assembly, so why mix rust (?) with clean oil? I don't know if lifters can get frozen from rust, but, they need to move freely. Heads up, there are dimples on one side of the rocker assembly shaft; I think two of those bolts that hold it down must align with those dimples or you'll damage it during reassembly.
Put the 60 axles under your 45: you will not regret it. They are 3" wider and will improve the road manners of your 45 immensely.
The rear is easy: move the spring perches inward 1.5"on each side (and you get a hand brake which actually works). The hard part is the front: you'll need to move the spring hangars outward 1.5". But it's really not that hard.
