Hi an update, I haven't been able to get much done with work and weather, however last night:
Jacked up front diff both wheels off ground, front left wheel spun freely the right had some resistance.
Started vehicle put it in gear, jumped out and the front drive shaft was turning neither wheel turned.
So will look at the other suggestions you guys made. Will report back tonight.
OK, you need to seriously look at the front differential.
We have seen folks buy trucks that had a block of wood shoved into an axle housing to plug it because the axle shaft was missing.
In order to drive it and you do NOT have a CDL switch on the dash:
Start the truck.
Place the transfer case shifter into the LOW RANGE position.
There SHOULD be a light come on the dash showing that the CDL is locked. If not, try to move back and forth a little and twist the steering wheel left and right a little to allow the system to "flex" and hopefully it will line up and the light will come on.
If the light comes on:
Place the truck in PARK and shut it off.
Go to the interior fuse block by your left knee (assuming LHD) and pull the DIFF fuse in the LOWER RIGHT of that fuse block.
Start the truck.
The CDL light should still be on.
Move the transfer case shifter to HIGH RANGE.
The truck should move and drive just fine forward and back now. This has locked the CDL and locking the front and rear drive lines together.
Drive it gently to make sure the front axle is not crunchy, banging or noisy. The front driveshaft SHOULD turn when moving, but your front tires may not be doing any work.
If the light does NOT come on:
Try the above anyway, it's possible the light has been disabled, been burned out, intentionally removed, or the CDL is not actually locking.
Report back with your findings.
forum.ih8mud.com
You have multiple possibilities.
1) Drive flanges are stripped.
2) Axle shafts in the front axle are broken or missing
3) Spider gears in the front differential are broken or missing.
4) All of the above and the CDL doesn't engage.
No matter what, you are looking at some serious diagnostic time and possibly exploratory surgery.
Good Luck!
Let us help when you need us and ask questions.
Sorry for the issues.
I'm positive the little old lady only drove it to church on Sundays and to get groceries.......
Never been offroad and it ran when parked......
