Did you push the button under the dash? I’m sorry I said 315s would work, they sure do on my 2009 LX.
No worries, not your fault at all.
I should say that the
product is awesome. It is the
literature that stinks.
With the TS408 handheld, I can read my OEM sensors in 2 seconds. I can get the ID off of them. I just need the sensor within about 4 inches, so you just push it up against the valve stem and it reads fine.
Then there are two options with your new sensors. Mine were already installed in the wheel and on the LX.
A. you can walk over to the new sensor and put the handheld up against the valve stem to make a connection with the new sensor and then manually enter in the ID that you want the new sensor to have, or
B. you can just hit a button and the handheld will automatically make a copy of the OEM sensor, in about 2 seconds, so that the new sensor now has the OEM ID. Same result as option A, just quicker.
Once either one of those are done, you can then scan the new sensor with the handheld and get the ID, pressure, temperature, I think one or two other facts.
So, I know that my new sensors are programmed. I can scan them and see the ID and the pressure, etc. I programmed them twice, using both options A and B.
My next step was to call Autel. That was horrible. After being on hold for about 12 minutes, I got a recording that nobody could take my call and please leave a message. Well, when you've been on hold for a while, and tuning out the pre-progammed messages, it can be easy to miss what was said, which is what happened to me. So after sitting for another 5 minutes, I hung up and called back. Same thing. I then called a few hours later and got through to someone. He did some quick research and said that the MY18 CANNOT receive real-time updates from the 315mhz sensors. The only thing the MY18 can do is turn on the low pressure dash light. In order to get the real time updates, you have to get the combo sensor. And he was very unapologetic about the complete lack of detail about this on any of tier literature.
So as I said, I can walk to each wheel, do a quick scan and see that I have the right ID and see the current pressure, etc., but I cannot get the PSI to display on my dash. I have not tried to if the sensors will notify me of low pressure.
Honestly (assuming they are correct and the dual mhm sensor will work), it is a really cool product. It would be worth someone buying the handheld, and then just passing it around to people. Once you clone your sensors, you really don't need the handheld any longer..
If anyone wants I could take a quick video and just walk through the process of doing one sensor.
