New to the forum..
Fort Drum NY
Well I have been lurking and reading alot here on the forum and I thought it was time to get registered and start running my yap some and asking tons of nubie questions.
first I guess a little about me would be in order.
I got my first cruiser right after high school. it is a 1970 FJ40 (built in 69).
once I saw it I knew I had to get it. and the price was right up my alley so I came up with the 450$ and drove it most of the way home, stuck in low range till I ran out of gas and the clutch and brakes crapped out on me all at once. so I pushed it the other 5 blocks to the house and started trying to figure out what to do with it.
I took it to a mechanic since I was only marginal at best at working on things myself at that time (I could swap auto trannys and such but I was afraid to try anything with a clutch back then).
I got her back on the road and I figured out why I ran out of gas...the fuel pump was shooting more fuel out on the ground then it was pumping to the carb. so I took it apart and did my first attempt at working on it. I took some silicone and sealed the big crack in the rubber gasket in the diaphram (probably not safe but I was really on a budget and it did stop the leak).
I ended up replacing the starter, and the water pump in the couple of years I had it running. then it developed a really bad knock that was not in the head so I parked it. and it sat for 11 years till I got a used motor from someone I met here in NY. I never really had the money to fix it and my ex-wife hated it (first sign that I should not have married her!) but while I was in afghanistan I found a 64 cruiser for parts on ebay in PA and the guy selling it was really cool about me picking it up after I got back so I have a 64 parts rig that runs (but it has the even older style intake and header, it looks original, just rusted out worse than the 70).
once I got it up here to NY we went to the parts store and ran into a guy who worked there and he had a 70 cruiser and he had pulled the motor out so he could do a v8 conversion and was looking to unload his F motor so I got it from him and loaded it in the back of the 64 and hauled the mess to Oklahoma where the 70 was and I swapped the motors out for the one in the back of the 64 so now the 70 runs! ;)
well the original motor in the 70 was toast because water got inside it somehow :mad: . I put the intake I got up here in NY in the 70, I wanted to keep the original carb but it was toast, the carb that came with the other motor needed rebuilding si I went to the parts store with the # of the carb and they said it was a holley 500 ( I thought it would be a holley 350...:confused: ) I could not seem to keep it from flooding, so I changed out the fuel pump. it had some crazy looking pump on it and I went back to the original pump. I also got a corect original carb for it and now she runs most of the time.
I rebuilt the brake master cylinder and installed new brake cylinders in the front, I have to find the right lines for the rear before I can install the ones for the rear tho.
right about this time I stumbled upon this site. seeing that I am not the only person bitten by the cruiser bug has been encourging. I hope you guys do not get too tired of my half-wit questions.
Anyway. I still ahve a ton of things to do to the 70 before she will be running well and not trying to kill me. I think that the next major project for it will be hysteer. I might go for new springs first tho. I do not have death wobble steering but I have bump steer from hell. I will post some pics as soon as I figure out how...
Finally. it is nice to meet you all! :cheers:
IF nothing else, you spirit of adventure alone says you'll fit right in. Welcome.:)
yeah, i'm trying to hit the 1000 mark, so i'll jump in for a "free" post.
welcome.
what for time frame was your story in?
in other words how long you had the 70?
Light Fighters.
Sounds like a definite labor of love, they all are. We're all looking forward to seeing pics. Welcome
