hi all,
looks like i finally took the plunge. wanted to give a BIG thanks to all who helped me out trying to sort things and make a buy. i'm rolling out tonight in an hour to drive it home insured and with a temp tag. car is a 1997 lx450 with 222K. i'm in austin texas.
anyone willing to help me with the following "needs list"? maybe some idea of how or whether to gang up other work with these repairs or whether i can do them individually. also whether they are manageable for a new(ish) wrench? or even some help on getting part numbers while i try to figure out how to navigate the online fiche?!
known needs:
A. radiator leaking > replace radiator.
B. P0110 code Airflow Meter > not sure.
C. P0172 code coolant temp sensor > not sure.
D. broken antenna > buy new antenna. i guess there is some issue with whether there may be damage to the motor? meaning first you need to buy the antenna, put it in and /then/ yo uwill know if the motor is bad? also - supposedly the "non-mechanical" antennas are not all that great?
E. broken heater control valve and plugged off hoses > buy new heater control valve and all hoses. replace all.
F. oil level sensor leaking > eventually replace or seal?
G. valve cover gasket leak > eventually replace. job for new wrench?
H. right rear door actuator not working > not sure.
I. cracked radius arm bushings > replace along with trackbar bushings.
J. light axle seal leak > eventually replace
THANKS ALL
jonathan
2.1.19 here is the "parts ID thread" i had to thrash my way through to wrap my head around some of the items. i updated it today with kind of a visual summary showing me trying to wrap my head around things. thought it might be helpful to some other new wrenches with new to me LC/LX's...
engine cleanup and under hood parts ID HELP?
known needs:
THANKS ALL
jonathan
