New stereo question, no answer at Audiophile :-(
I bought a new system consisting of:
Kenwood DNX-8120 HU
Polk db6501 Front (6.5inch, 100w RMS)
Polk db501 Rear (5inch, 35w RMS)
Kenwood KSC-SW10 Powered Sub
Ok, the HU outputs 50w per channel, 22w RMS per channel. That isn't quite enough to drive the fronts at their full power, or up to their potential, as I understand it, so I was contemplating an amplifier.
Now, I was looking at KAC-8404 this Kenwood amp, its 600w X 4 channel, 50w RMS per, or bridged 180w RMS per 2 channels.
Do I only want a two channel amp, to run the front two speakers, as they can really use the extra power (and the deck puts out almost enough power to max out the two 5" speakers), or should I get a full 4 channel amp? Do they make 4 channel amps that have their output as adjustable? Like could I run on a 600w amp, 200w on two channels, and 100w on two? What should I do? I am so confused! Thanks!!
Not to harrass you but this question would be better answered in the Electronics section, no?
You will want to amp those front speakers. Run the rears off HU power and use them for rear fill only (most sound faded towards the front).
Here is a good example of an excellent budget amp that would be a good match for your front stage.
New Cerwin Vega EXL-350.2 2 1 Channel Car Amplifier NR - eBay (item 120275111618 end time Jun-27-08 11:49:41 PDT)
Don't let the price or the Cerwin Vega name deter you, this amp is the same design as used in some high end brands like Zapco and ARC. Only Chinese produced and being phased out by CV.
Into 4 ohms, this amp will push 110watts into 2 channels.
I bought 2 of these (back when you could buy them for $32 each), and they are solidly built. I haven't installed them yet, but others have bench tested them and they put out the rated power and more.
To answer your question, yes, on 4 channel amps, you can adjust the output of the front and rear channels separately, you do this with the gain controls on the amp.
Good luck and don't forget to sound deaden the doors.
"Do they make 4 channel amps that have their output as adjustable? Like could I run on a 600w amp, 200w on two channels, and 100w on two? What should I do? I am so confused! Thanks!!"
Like Ivan80 said, the gains are used to adjust the levels of each channel but if the amp is rated at 50w x 4 you won't get any more than it's rated for to each ch. The output devices are fixed and assigned inside the amp for the corresponding channel. and dito on Ivan80's excellent advise.
