I have cut out my basically non-existent rear crossmember and sill. I built a new crossmember out of 2"x2" square stock. I cut out holes where the body mounts go, but other than that it is a continuous tube.
I want to treat it before putting it back in permanently. I was planning on using POR15 on the inside. I figured that I would tape off the openings, pour in the POR15, slosh it around then pour out the excess. Then paint the whole thing with weld-through primer.
My problem will be when I go to spot weld the new rear sill to the crossmember. What will the heat of the spot welds do to the POR15 inside the tube? Should I plan on resealing it somehow once all the bodywork is final welded?
I'm just looking to not have to redo all this bodywork again in 15 years.
