New Radio Installation
Rogers, Arkansas
I'm having a problem wiring my new radio. Each time I turn the igition off, the clock and the radio loss their settings. I figure there is a wire not connected or mis-connected. Any suggestions. I've looked at the FSM and the wiring diagram seems easy, but I can't get it to work.
Help
Thanks
If it's an aftermarket radio then it has two different power wires. One for power when the radio is on(power w/ key)and the other one is power at all times for memory keep alive. Red should be keyed on and yellow should be keep alive. I could be wrong, guessing off the top of my head, just on the color codes of the wires.
The wires are red and yellow as you suggest. Do you happen to know where I can find the all time power? I'm using the original radio harness. Gray is the keyed power, which one is the all-time power?
