New radiator leak question
Discussion in '80-Series Tech' started by Cruiserhead05, Jul 19, 2005.
  1. Cruiserhead05
    Cruiserhead05
    3,611
    197
    Jun 25, 2003
    Rixeyville, VA
    Ok, i promiose i searched and did find some helpful stuff but nothing exactly like my current problem..
    I replaced my radiator 2-3months, its done fine ever since.
    A week ago my phh went on a road trip, had it fixed.
    the truck has 250k miles, HG already done at 200k
    Starting yesterday, when i drive the truck and then turn it off i will get a small leak coming directly underneath the radiator on the PS.
    It doesnt leak when the truck is running, only when i turn it off. i noticed my cap was pretty older, i think the original so i got a new one.
    It seemed to help the problem a little, its doesnt leak horribly, just a small stream....the truck is still driveable.
    Is it possible the rad. could be faulty? the lower hose is NOT the problem, no leaks from there. I did not another hose going into the rad. close to that area that could be a problem, its small and goes in via a 14-16mm nut? i think...
  2. Cruiserhead05
    Cruiserhead05
    3,611
    197
    Jun 25, 2003
    Rixeyville, VA
    ok i found it. at the bottom of the radiator on the pass. side there is a small, maybe an inch longer hairlind crack in the plastic, it wiped it all dry and could see the fluid slowly start to leak out. Now, do i need another radiator, this new one should still be under warranty so im not too worried about it, or can i do anything to fix just a small crack like this.
  3. mtycruiser
    mtycruiser
    179
    2
    Dec 11, 2003
    If it's under warranty, I would change it.
  4. Heffenoche
    Heffenoche
    517
    1
    Dec 22, 2003
    VA
    Get it replaced under warranty. :cool: If it is possible to fix I doubt it would ever be as reliable as one that has never been cracked.
