Hi Everyone!
New owner here and and wanted pass along my thanks for everyone on this site. It’s already saved me countless hours and $$$. I am the proud new owner of a 170,000 mile 1996 Land Cruiser. I’m a maintenance freak and have already started planning my front axle rebuild, although it’s showing no signs of needing done. It does need front brakes and will do with a quick pad replacement until I have the items and time necessary to do the rotors and subsequent front axle job with birf switch. I did an oil change when I bought the truck and went with 0w20 being from Ohio with cold starts this time of year. After 1,500 miles I noticed this wet area around the valve cover/dizzy area I have seen zero loss of oil on the dipstick and zero oil under the truck The oil still looks brand new after 1,500 miles which along with its smooth performance and even sound tells me I have a very healthy engine. Anyone have any advice on this apparently small oil leak? I have everything I need to do a valve cover gasket replacement (plugs, boots, PCV, throttle body gasket, plug seals, half moons, plug wires, and dizzy cap and rotor. Just curious on some opinions of this oil leak and if I’m doing the right thing with the valve cover gasket replacement Should I also be doing the dizzy gasket/seal? I guess I’m a little concerned about removing the dizzy and altering the timing of this smooth runner
Thanks again to everyone on this awesome site!
