Don't fix it! Leaking by design. That's what keeps the undercarriage from rusting.
You do realize that one of those pics is the driveshaft yoke and is "leaking oil" from over-greasing the slip yoke.......right?
Thanks for the great information. Tightening down the oil pan (hopefully not too tight) has significantly slowed down the leak it seems. Cleaned up under there a bit, too.Welcome, and congrats. How often does the puddle appear, i.e. rate of loss? What color and smell?
Remember, in a 3FE the oil filter is upside down on the top of the engine. Every time an oil change is performed, engine oil leaks all over the place. My rig has a fresh oil smell every time I drive it, the undercarriage is a complete mess, and sometimes I see one or two drops underneath.
Don't tear your hair out just yet, you will be fixing this and that for a long time as you bring it up to speed (though it sounds like you found a well maintained rig). These vehicles were built with very good durability and with the utmost integrity of Toyota technicians. Keep a close eye on the main 5 for the first 6 months (or always ) including engine, transmission, front and rear diff, and transfer. The problem should manifest sooner or later.
If the fluid is literally dripping out, just take it to a mechanic for piece of mind, you just got it! You do not want to waste time and money on fixing the wrong thing (ask me how I know ). If you do not have a shop, I recommend avoiding chains or big, well established ones. The small garage that has been around a while will take more time in educating/working with you, and you can gain trust/rapport with them. Plus, they have more experience with the older rigs (usually).
My biggest piece of advice as a new 3FE owner is to watch your temp gauge like a hawk, do a radiator flush and pressure test your cooling system.
