Hi all,
New to the forums, I've read lots but just purchased my truck so I figured I'd make an account. It's a very clean 1990 Toyota Hilux Surf SSR Limited, with the 2L-TII mechanically injected diesel and a 5 speed (and yes, I know all about the head issues!). The truck has 122,000 km on it, and the head and front end of the engine just replaced. The previous owner also advanced the timing a bit to make it run cooler he said. The head was ordered from New Zealand apparently, but I am unsure if it is an OEM Toyota replacement 2L-TII head, a 3L head, or an aftermarket redesign. Does anyone have any idea what it would most likely be, coming out of New Zealand? Are there any markings on it that would give me any indication?
In any case, the truck runs great, and I am currently driving it across Canada from Saskatchewan to Nova Scotia (about 4300km) . The temp gauge stays still and it's averaged 32 mpg thus far. We've been sticking to 100km/h and downshifting for the big hills.
I've read lots about the 2L-TE, but have not seen very much about it's mechanically-injected counterpart, the 2L-TII. Am I correct in saying they are the same, minus the pump? I've read GTSSportCoupe's guide on improving the 2L-TE and will be doing many of those modifications to this rig when I get it home.
First thing, the glow plug light only stays on for about a second and a half before going out, making the truck a bit hard to start when cold. I'm thinking this is the glow plug relay, are the glow plug relays for the 2L-TE and 2L-TII the same? Because I see two listed on eBay, one for the 2H, 2L, and 2L-T, and then one for the 2L-TE and 3L, and they look completely different.
Second, I know the 2L-TE has a boost sensor, which will add fuel when it sees more boost, but does the 2L-TII have a way of doing this or will I immediately start leaning it out when I introduce more air? It's said that ~12psi is what's safe to run on the 2L-TE, so would this be about the same on the 2L-TII? I know that I don't see much smoke at all out the tailpipe of this thing.
Thirdly, and lastly for now, the clutch pedal on this thing is sooooft, appears the slave cylinder leaking and on its way out the door. We will need to do something about it before we hit Ottawa as it's getting hard to change gear. Can anyone confirm if the slave cylinder for the Surf would be the same as any other North American spec 4Runner with the R150F?
I'm absolutely loving this truck and plan to add a pyrometer, aftermarket temp gauge, boost gauge, up the boost a pound or two, 2.5" straight pipe, and block off the EGR and PCV when we get home. I may also do a snorkel and Evan's Waterless coolant, if funds permit. Has anyone had experience with the stuff?
Any help or info at all would be greatly appreciated, thanks in advance!
