well guys I've owned my new LX for 2 days now: New owner - '00 LX and build thread
and already heard just about the worst sound possible. I hadn't driven the car all day and was going to take it to the gym. It's probably 45 degrees or so outside. I go to turn on the car, starts fine but then the sound of someone strangling a seagull from behind the dash.
Shortly after, all the warning lights came on: ABS, VSC etc. with a constant loud beep/alarm that won't go off. Weirdly enough, the brake pedal felt fine.
I tried disconnecting the battery, but it didn't help. The issue came right back.
I've been poking around and it looks like the hideously expensive Brake Master Cylinder / Accumulator / Actuator is acting up.
My only possible saving grace here is that the previous owner had it serviced meticulously at the same Lexus dealer. I signed into Lexus Drivers service history, and the most recent service history was at 209k miles in June 2017 (I have 214k miles now). Here's what it says in the service:
"CUSTOMER STATES THEY HAVE A LARGE BRAKE FLUID LEAK. YESTERDAY BRAKE LIGHT CAME ON AND FLUID WAS FOUND VERY LOW. CUSTOMER ADDED FLUID AND NOTED AN PUDDLE ON DRIVEWAY. INSPECT AND ADVISE. ~|~ ~|~209146 FOUND BRAKE ACTUATOR TO HAVE LARGE HOLE ON BOTTOM ON THE CUP SEAL RECOMMEND BRAKE ACTUATOR AND FLUSH AND RECHECK"
It cuts off there so I plan to call the dealership that did the work tomorrow and get more detail. I can't quite tell, but it sounds like they replaced the unit already?
Does anyone know if that part would still be under warranty if it was 6/21/17? Even though the car has changed owners?
I really hope so... What a day ruiner
