I also purchased from Yam6 and had an independent mechanic install - no problems to date. Initially I was concerned about a slight humming sound (only on start and when brake pedal depressed), but after further research this appears to be normal. Yam6 claims the part is genuine, it arrived in a Toyota box with the correct part# on the box, but there are no markings on the unit itself.So how is your Master Cylinder from ebay holding up?
I doubt new battery had any bad effect. But water entry (around windshield is all to common) and low fluid may have.
Keep in mind this is only one possible cause of your issue. When I hear problem(s) coming and going, I first look to moisture!
It's fine too wash around wipers & windshield. But if windshield has ever been replaced, chances are the installer did a poor jobs. Openings around windshield allowing water penetration.
1) Installer drills new holes and use screws to fasten molding. This leaves the factory rivet holes open. They also fail to plug factory alignment holes along top.
2) Nicking or scratching paint under windshield, and then not adequately protecting bare metal. Over time holes from rust develop through the body.
Water then travels down the "A" pillar(s), during washing or rain/snow storms. This gets into electronics inside cabin side panels. This causes all kinds of issues. Then after drying out everything is fine again. Over time this causing all kinds of permanent damage.
