New LX450!
Discussion in 'VA/DC/MD- Capital Land Cruiser Club' started by Betteron2wheels, Sep 17, 2017.
  1. apinti
    apinti
    257
    199
    Jul 25, 2014
    Leesburg VA
    Looks good. Do you raise the valve or lower it? I always get confused about iy.
  2. shmukster
    shmukster
    5,100
    1,629
    Apr 20, 2003
    NE PA coal region
    Curious as why you went with Deutsch tech shocks instead of OME?
  3. apinti
    apinti
    257
    199
    Jul 25, 2014
    Leesburg VA
    I almost asked the same question. Also, what bushings are those? Mine came with yellow poly inserts, and only two of them.
  4. Betteron2wheels
    Betteron2wheels SILVER Star
    143
    175
    Apr 9, 2013
    D.C. Metro
    Lowered, it seemed to be the consensus on here on mud MUD, and it makes since. The suspension went lower (relative to the frame), so the valve should go low too. I used a punch and made 2 marks on the valve body and mount for reference. It seems like the brakes are better but I haven't had a chance to fully test yet.
    apinti likes this.
  5. Betteron2wheels
    143
    175
    Apr 9, 2013
    D.C. Metro
    apinti likes this.
  6. Betteron2wheels
    143
    175
    Apr 9, 2013
    D.C. Metro
    I did a ton of reading on various shocks and found mixed reviews on the Nitros, Bilstiens, KYB, rancho etc...but mostly good feedback for the Doestch shocks. Many of them started with "for the price..." because they were cheap, about $200 for the set and I couldn't stomach the price for Fox or Icons. And I was able to call the company and speak with an employ that helped me choose.
    Plus, I probably wouldn’t know if the Doestch suck because shocks that came on the truck were so bad anything would be an improvement; The passenger rear was covered in its own fluids and had zero damping.
    The caster bushings came from Slee, made by Dobinson. They are adjustable and work up to 4" lift. I assume they are easier to install since there’s no outer metal sleeve. I used a rubber mallet to tap them into place.
  7. apinti
    apinti
    257
    199
    Jul 25, 2014
    Leesburg VA
    I've got OME 2.5" heavy package from slee and it came with two caster bushings. It took a 12t press to install them. How much lift did you get after install?
  8. Crusha
    Crusha Self-censoring my mud posts... SILVER Star
    2,120
    2,729
    Oct 8, 2013
    Chester Springs, Pa.
    80 brakes on a built truck are :poop:
    Betteron2wheels and apinti like this.
  9. Betteron2wheels
    143
    175
    Apr 9, 2013
    D.C. Metro
    I didn't do a very good before and after but I think I'm about 3.5 rear and 3 in the front. Thats with no spare and spare carrier removed.
    apinti likes this.
