I just received my new Rough Country 4" lift kit in the mail and opened up all the boxes to check everything and read through the install instructions thoroughly. In the instructions it says to be sure and install with the "fat part" of the shims facing the back on the front springs and the "fat part" of the shim facing the front on the rear springs. Only problem is there are no shims... I called the tech line and he told me the instructions were probably written 20 years ago and he is pretty sure I don't need them because the springs have been redesigned to correct the pinion angles without shims. I'm not sure how that is, because the leaves and all the spring packs are all the same thickness. Anyone had any experience with this? I don't want to install it and have my steering screwed up because it needed shims.
