New J's & Toyo's
Discussion in '80-Series Tech' started by Kazmanff, Jul 15, 2005.
  1. Kazmanff
    Kazmanff
    81
    Feb 8, 2005
    Bremerton, WA
    Just installed my new OME lift. Went with J springs F&R with Mr. G's up front to keep it level and a set of 285/75-16 Toyo Open Country M/Ts :bounce: . Did the lift at the auto shop on base, so I had a full compliment of tools, a lift, and a press for the bushings. All in all I call it a :banana: to :banana: :banana: job, more labor than skill. I have Slee's caster plates being delivered as even with the OME CC bushings I still ended up with -0.7 & -0.4 degrees of caster. I talked to Dennis at Slee and realized I would have to go dumpster diving for my stock bushings, as usual no luck. Picked up the phone and ordered up a set from C-Dan (nice guy by the way). I'll have more pics of the caster plates as well as a follow up alignment report when I get them on in a couple of days. Enough jabber, on to the pics.
  2. Kazmanff
    Kazmanff
    81
    Feb 8, 2005
    Bremerton, WA
    Stock
  3. Kazmanff
    Kazmanff
    81
    Feb 8, 2005
    Bremerton, WA
    Lifted.
  4. Kazmanff
    Kazmanff
    81
    Feb 8, 2005
    Bremerton, WA
    Another angle.
  5. clarkrw3
    clarkrw3
    1,595
    Albums:
    1
    1
    Nov 29, 2004
    Tempe, AZ
    very nice congrats :cheers:
  6. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,720
    7,574
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    Nice stance. What shocks did you choose?
  7. Kazmanff
    Kazmanff
    81
    Feb 8, 2005
    Bremerton, WA
    73/74 L's.
  8. cruiserdan
    22,720
    7,574
    Mar 27, 2003
    You have lowered your bump stops as well then?
  9. Kazmanff
    Kazmanff
    81
    Feb 8, 2005
    Bremerton, WA
    Not yet, figured I was going to have to soon, is there an easy way to do it?
  10. cruiserdan
    22,720
    7,574
    Mar 27, 2003
    I can not advise you on the best way to approach that. I can tell you to excerise caution when articulating as it will be possible to bottom-out the shocks and damage them with the bumpstops in the stock location. If I understand correctly, you will need to lower the stops at least 1 1/2 inches to prevent damaging the shocks. I trust that you have lowered the sway bars to prevent front drive shaft damage at full droop?
  11. Kazmanff
    Kazmanff
    81
    Feb 8, 2005
    Bremerton, WA
    yup, gonna be a little while before I can get her off road and test her out anyway, plan to replace the brake lines with extended SS soon also.
  12. Boston Mangler
    Boston Mangler
    3,589
    5
    May 21, 2004
    San Diego
    Looking good! Congrats!
    Please let us know how the caster plates effect the ride. I just installed the 850/863 (non J) with the MR G spacers and i dont want to install the bushings if the caster plates will be better.
    Thanks
    Kevin
  13. NorCalDoug
    NorCalDoug problems solved daily...
    6,294
    120
    Oct 27, 2003
    uhhhh...duh...Northern CA
    Very nice. :D
    Sliders, bumpers next ;)
  14. T Y L E R
    T Y L E R
    2,597
    6
    Mar 27, 2003
    Did the 96 LX come with stock front bumpstops ? If not I bet Dan knows the stock # for 'em and where to fly them in from ;) . Ask him how he knows .. :eek:
    Thanks again CDan,
    :cheers:
    TY
  15. crash
    crash
    89
    Sep 23, 2003
    With the L shocks, you will definitely want to extend you diff breathers, also. They will pop off the axle at extension and then the fluid will splash or spray out the connection while driving home from wheeling. Not a critical issue, but I figured I would warn you before you get diff oil everywhere.
  16. MLX450
    MLX450
    630
    10
    Apr 10, 2005
    WA
    Nice!
  17. lahar50
    lahar50
    452
    Feb 27, 2005
    Indiana
    Very nice
  18. phatairman
    phatairman SILVER Star
    474
    21
    Apr 28, 2003
    Atlanta
    Super Nice!!!
  19. 4x4CPOSEADOG
    4x4CPOSEADOG
    2,588
    11
    Jul 14, 2004
    on the right coast
    Nice looking rig. Yo Kazman, are you in the Navy by chance?
  20. Kazmanff
    Kazmanff
    81
    Feb 8, 2005
    Bremerton, WA
    Ex HM3(SS), Fed Fire now. :cheers:
