New GM column ? two white wires on ignition
Fresno, CA
Ok guys i searched under many words so somebody help me out. I have a GM tilt column unknown year and it has two white wires ob the ignition switch i can tell you its later then about 88 cause that ignition switch i bought doesn't fit it. So what do i have, theres no turning back i already have the wieing harness hooked up to it (at least i think i do). So what is it and what do i do? any help links etc are appriciated
thank you
Just went out and looked at the GM column that I am currently installing in my 40. The column is out of an '89 GMC Jimmy. No white wires' but there are two heavy guage red wires that were both 12v incoming power ( the only two wires of the same color on the switch). I went down to the local library and looked up the wiring diagram for this year column, made a copy, then had it laminated at Staples. You might make a list of the color and number of wires, go to the library, and start looking at different years of diagrams to see if you can find one that matches yours.
What steering box are you using? Saginaw? My 40 had a sag manual box already on it done by the PO. The new GM column had the 1" DD output end on it, so I had to start from scratch to connect to the sag box. I went to the local pick-a-part and got two upper u-joints, with shaft, off of Astro steering shafts. This u-joint was a direct bolt up to the DD end on the GM column. I also got two complete shafts off of 80's era GM S-10 pickup/Blazer. These shafts have rag joints on the bottom end and a joint on the upper end that does not have enough flex. I took both joints off, mated one of the Astro joints w/shaft (welded) to the upper end of the S-10 shaft, and the other Astro joint to the bottem end of the S-10 shaft, (bolt on). This is almost a direct bolt together shaft. Some welding is required to mate the upper shaft/joint and a splined coupler for the sag box to the lower joint. Hope this clear. I have pics but don't know enough to be able to know how to post them. Maybe I can get lucky and peel my son away from his computer to get them posted.
Pics would help.
Are they thin wires going to the key/tumbler area? Could be the anti-theft (PATS) Could be the "key in lock" reminder.
Do they go to the ign switch itself?
Did the column have an air bag? These wires are usually yellow sleaved.
74fj40---I am interested in the wiper wiring diagram. That is the only area that I am having trouble with figuring out.
Yoda---tried posting pics the other night, could not figure it out. Any tips?
cardinal fang said:
Go to this link at pirate. Texican's writeup, he knows his stuff.
Hey Cardinal--Thanks for the link. The schematic looks like just what I need to finish figuring out the wiper switch. Some of the things on that thread are what I have already gone through, modifying the column mounts, etc. I have pics of what I am doing to connect the column to the sag box. I will post them when I can figure out how to, lack of time and lack of computer knowledge are slowing it down.
