new engine, oil spewing from front of engine
Moab Utah
I know that this is most likely the timing cover, but the mechanic that rebuilt the engine was recommended by a cruiser mechanic in town, and the shop builds quite a few land cruiser engines. so the question is, Is there something else it could be? At first it looked like it was coming from the front drivers side side of the oil pan. I tightened the bolts, and they were kind of loose, but that did not help. It is poring out pretty quickly. Also it seems that the oil pressure is pretty high, but I am not sure if the gauge is correct.
There's a oil galley plug on the left side front that sometimes leaks....... can you clean it up and see for sure??
A lot of people have had this problem after rebuild the plug doesn't get put back. Do search for oil galley plug, should pull a bunch of stuff up, and don't drive it until it's fixed.
Maybe I am a little confused. Isn't the oil galley plug the one right above the #4 or #5 spark plug? He has a leak from the front.
Do a search for timing gears and rebuild. I don't have first hand knowledge, but I seem to recall there is an issue with the timing gears. It is something about screwing something in too far or a bad casting on certain gears. That seems more likely if you have a leak from the front.
There's that little oil squirter in the front plate that, if tightened down to far, will push the front plate away from the block. That would cause an oil leak as you describe...
