1. An upgrade is pending. The site is only accessible in debug mode.
    Complete Upgrade
new brakes for my '97 fzj80
Discussion in '80-Series Tech' started by destiny unbound, Aug 26, 2006.
  1. destiny unbound
    destiny unbound
    1
    Aug 26, 2006
    confused as two what the difference is between cross drilled and dimpled when it come to rotors for the iron pig-- I have been going through brakes quite rapidly. any suggestions??
  2. CruiserLegolas
    CruiserLegolas
    143
    3
    Apr 4, 2004
    Los Angeles
    Some people, including myself, have replaced the front rotors with new OEM rotors and upgraded the pads to those from the 100-series. The 100-series brake pads last a lot longer than the 80-series brake pads.
  3. beno
    beno Gihee Arakawa Moderator GOLD Star
    23,893
    Media:
    382
    Albums:
    29
    19,185
    Aug 28, 2004
    Woodstock, NY
    Are you going through rotors or pads quickly?
    x2 the suggestion to go up to 100 series pads in the front.
    If you are lifted, and you have not adjusted the LSPV in the rear, your rears will wear quickly. The LSPV needs to be adjusted to compensate for the change in height of the vehicle.
  4. nakman
    nakman addict.
    2,277
    390
    Jul 30, 2003
    Broomfield, Colorado
    All of the above, and maybe suggest a caliper rebuild? You don't give us a lot of info to work with though.. define "going through brakes" :)
