Those are exactly what I have on my 80 with the ARB expedition rack. May be time for an upgrade.I’ve never paid much attention to the standard arb towers. Here’s what they’re showing for the new rack.
I do like the ARB Base Rack a lot. I don't hear any wind noise coming from the roof rack with the wind deflector--even at 75-80mph. Without the wind deflector though I did hear wind noise so the wind deflector is a must have. Only noise I hear at highway speed is a pesky little whistling noise coming into the cab from the passenger side mirror (just needs to be sealed up), but this noise is unrelated to the roof rack. Even loaded up with two 20L Scepter jerry cans of water and two 20L jerry cans of fuel, a full 20lb propane gas bottle, a mini propane fire pit, camping gear, etc, I could not hear any noises coming from the load or the roof rack at highway speed. So needless to say I don't have any buyers remorse and based on my experience with the ARB Base Rack I would recommend and give it a thumbs up.Following - would love to hear how people are liking their new base racks, wind noise, mounting existing boxes, and anything else.
Great photos! Appreciate the review as well. Did you ever figure out how to use your Thule box (if I'm remembering correctly)? I've wanted an awning for a while so good to hear it hasn't introduced any new noises. I assume it mounts well since they are both ARB.Since the last trip in the pics above I've added a full length ARB Awning and also moved the rack toward the rear a bit and still don't hear any noises from it at highway speed.
I appreciate that, thanks! Yeah I hear you, mine has some small spot clear coat fading issues as well which I will eventually get around to fixing. Actually I've been going down the research rabbit hole over the past few days on how to fix, blend clear coat, etc as I like to try and fix myself at some point. I have a few upgrades planned most notably the Wholesale Auto Transmission Valve Body upgrade for the A440F that I am about ready to pull the trigger on (gosh I can't waitGreat photos! Appreciate the review as well. Did you ever figure out how to use your Thule box (if I'm remembering correctly)? I've wanted an awning for a while so good to hear it hasn't introduced any new noises. I assume it mounts well since they are both ARB.
Sidenote: Great looking truck. It's motivating me to fix some of my paint issues and decide about replacing some windows or doing some tinting.
).Nice RACK!I don’t plan to use my sunroof much, so I opted for the 84” Base Rack. Took a bunch of little tweaks to get it mounted just right. Only thing I don’t like is the proximity of the gutter clamp to the front doors. It’s a tight fit...if you don’t get it secured just right, you may not be able to open your doors. Not sure why I didn’t receive a wind defector with mine? I contacted ARB Customer service and awaiting their response. Part number is ARB BASE81. View attachment 2678622View attachment 2678623View attachment 2678624
So after I re-oriented the rack more toward the rear I can use the tilt function and open/close without any restriction. Before I moved the rack toward the rear I was not able to use the tilt feature because the crossbar/slat was directly over where the high point of the moonroof glass would stick out above the surrounding roof. After moving the rack toward the rear just a bit, when in the tilt position the high point of the moonroof glass now falls in between the slats/crossbars (yet is also not high enough to touch anything mounted up on the rack). The BASE Rack is fully height adjustable so I could have raised it up to clear the moonroof when tilted up if I didn't want to re-orient the rack toward the rear, but my preference is to have the BASE Rack at the lowest setting so it's nice and snug to the roof.@ RETRO LC Are you able to open your moon roof cruising around town with your rack on? Wind noise normal or increased? Thanks for the great pictures.
Wow it’s that close to the roof , awesome!!So after I re-oriented the rack more toward the rear I can use the tilt function and open/close without any restriction. Before I moved the rack toward the rear I was not able to use the tilt feature because the crossbar/slat was directly over where the high point of the moonroof glass would stick out above the surrounding roof. After moving the rack toward the rear just a bit, when in the tilt position the high point of the moonroof glass now falls in between the slats/crossbars (yet is also not high enough to touch anything mounted up on the rack). The BASE Rack is fully height adjustable so I could have raised it up to clear the moonroof when tilted up if I didn't want to re-orient the rack toward the rear, but my preference is to have the BASE Rack at the lowest setting so it's nice and snug to the roof.
I honestly don't use the moonroof too much, but when I did I don't recall it being any noisier than having the moonroof open all by itself without the BASE Rack. The wind deflector is a must with this rack. With the moonroof shut, I can't hear any roof rack related noise with the wind deflector, but without the wind deflector the noise was definitely noticeable and bothersome.
Is this the BASE81 84”?I do like the ARB Base Rack a lot. I don't hear any wind noise coming from the roof rack with the wind deflector--even at 75-80mph. Without the wind deflector though I did hear wind noise so the wind deflector is a must have. Only noise I hear at highway speed is a pesky little whistling noise coming into the cab from the passenger side mirror (just needs to be sealed up), but this noise is unrelated to the roof rack. Even loaded up with two 20L Scepter jerry cans of water and two 20L jerry cans of fuel, a full 20lb propane gas bottle, a mini propane fire pit, camping gear, etc, I could not hear any noises coming from the load or the roof rack at highway speed. So needless to say I don't have any buyers remorse and based on my experience with the ARB Base Rack I would recommend and give it a thumbs up.
View attachment 3227453View attachment 3227455View attachment 3227460View attachment 3227461View attachment 3227462
Yup, that’s the one. ARB Part# BASE81 = 84”x51”Is this the BASE81 84”?
