Just bought a 89 BJ 74. She runs and drives fairly well, but I have some things to do to make her right. I have some questions that perhaps need more threads, but If anyone is willing to answer here then that's great.
1. I need a heater core anyone know a good source in the US for a 70 series heater core?
2. Need a new radiator. I see many on Ebay, but not sure if they actually fit even though they say they do. Price range I'm seeing is $125-250. Any advice?
3. I don't have air conditioning and I want it. I'm not sure if the factory "air box" has enough room to add a evaporator core in on top of the heater core. I don't see the room for a aftermarket underdash unit as the shifters will hit it. Theres room on top of the dash, but not sure of the depth. Any advice on this?
4. I am considering a "fuel heater" or relocated heater core/bus heater and then having the place of the current heater core open for a evaporater core and AC. Any advice on this?
5. Anyone have a source for a 3b diesel AC compressor bracket and whatever different "waterneck" may be required? Currently I have a idler pully and no compressor.
6. The rear door sags from the weight of the tire over the years and is hard to shut tight. Is there a way to re-align/adjust the hinges?
7. Any good part source for "dash parts" such as vent louvers etc. alot of my dash pieces are cracked up?
8. I do not have locking hubs, or auto-locking hubs they are solid and the axle is turning with the wheels all the time. Is it relatively simple to install locking hubs such as Aisin or warn?
I'm in the US so I can't just go to a wrecking yard and find another 70 series study, to canablize or get parts from. I can only search online and try to find something that works.
Any advice appreciated.
For items 1, 3, 5, and 7 it may also be worth talking with @joekatana. That's where I managed to find my heater assembly.
And welcome!
Let me help you with number 8....don't bother. Welcome btw!
I buy a lot of parts through Partsouq.com. Another good resource is ToyoDIY.com. Same MO; put your vin number in and you can pull up parts diagrams.
Curious why you say this? Why not bother with installing selectable hubs? I've been planning to do it. Convince me it's pointless so I can save the money... =)
Possibly. You won’t know a thing until you remove the head.
None of this is rocket science. These are 30+ year old engines.
You are throwing the bathtub out with the bath water without actually knowing what you are dealing with or even if things are as bad as you think they might be.
Take one step at a time dude.
Onur's on the mark here. Heartbreaking to have this happen immediately after purchase. But get some pics posted up, find the 3B engine manuals available here on the forum, and engage the cruiserhead braintrust. You can work through this and be posting lovely sunrise photos like @FJBen before you know it.
Rob,
Welcome to the forum and I’m sorry you are having such a bad first experience with your truck. Where in NC are you located? I’m in Greensboro and know a little bit about these trucks, especially the imports from Spain. I’ve got some rear door hinges and dash parts. Can you post a few pictures? An engine picture of two might help give us an idea what you are working with. I would have the radiator recored. It will be better than a Chinese built radiator and cheaper than a Toyota radiator. In my experience, most of the Spanish trucks I’ve seen were running straight water in the cooling system with NO coolant. They don’t need anti freeze in Spain and they don’t run it. The problem with straight water is the rusting and gunking that happens inside the engine, radiator and heater core. Your heater core is probably plugged up with rust and silt, may be the same problem with the radiator. You may be able to have the radiator hot tanked and cleaned up. I have a lot more questions than answers right now. I’d be very interested in seeing some pictures of the engine and engine bay. Can you post some? I’ve seen lot of thrown together Spanish trucks and want to see what you have. It will make assisting you easier.
Chris
Perfect example of the braintrust around here. Find your local folks like Chris and move forward.
And oh yeah... we need pics!!!
