I just purchased a 40 that seems to have some carb problems. It has a weber 32/36 carb. It was having backfire (through the carb) problems right after buying it and driving home. It was very sluggish to accelerate also and would only do about 45 mph.
As soon as I got home I sent it to a shop and had them rebuild carb. Mechanic said that the choke spring was kind of weak and might need replacing. Also said first stage jets might need enlarging. It seems to run a little better but sometimes does not start or idle very well. It also seems to have a small back fire through tailpipe that is noticeable when letting off accelerator. It pops a few times either in gear and decelerating or when not in gear and getting off the gas.
The PO had a rebuilt aisin carb that was included in the purchase. I am trying to figure out if I should make the jump to the aisin or if after the weber rebuild maybe it is not a carb problem. Also has a rotary knob fuel regulator which I am not sure how to adjust to make it lean or rich. Are larger numbers making fuel more rich? Is a back fire a rich or lean problem. Looking on the internets I see where some say rich and some say lean caused back fires.
If I do make the jump to the aisin how can I determine what OEM parts I need to get back to that set up?
I also am not opposed to doing and EFI kit if I think it will clear up my problems.
I am a complete newb when it comes to working on cars, especially carbs. Assume I know nothing!
Thanks for the help.
