Never ending axle service
iptman
Northern VA
Well... I'm back at it. Here's hoping for better luck this time around. Incidentally, if anyone is driving past Ryan's shop this week on the way to the meeting, let me know.
iptman
Northern VA
Do the bottom shims actually do anything? Apparently all my shims are on the bottom and none on the top. That can't be right.
Stumpalama
Forum Junkie
NOVA
I'd say you did something wrong if that is the case. The way I see it, the idea is for the shims to do double duty, one job is to center the knuckle, the second job is to adjust proper preload on the trunnion bearings.
Stumpalama
Forum Junkie
NOVA
Which one was the most soupy? Did you notice wear on the axle seal?
iptman
Northern VA
DS was way worse where I had all the shims on the bottom. PS was better, I could still discern the greenish color of the bearing grease in the hub and on the spindle. DS it was all gray. On the PS I had shims on both top and bottom.
Couldn't tell on wear on the axle seal. I'll look again tomorrow. I just popped then out and dropped them in the tray.
Jakes40
IH8MUD Poser
Winchester,Va
You should not have all your shims on one side.
I came up with numbers that had all my shims on the bottom. I did the math a couple of times also. I was miss reading a step. That put all the shims on the bottom.
iptman
Northern VA
So now that I have both sides broken down I'd like to swap the front 3rd. Are there any tricks to doing this? I've never done it before.
iptman
Northern VA
Will the 3rd stay on the studs of the axle after all the nuts are off or do I need to be ready for 70 pounds of metal to fall off when the last nut comes off and I break the seal of the factory FIPG.
iptman
Northern VA
Also, what's the yellow paint called that you use to test a R&P mesh pattern? And do you think I can get it at Napa or Advanced?
iptman
Northern VA
Success. Cleaning that gasket off was a pain in the ass. So do I use a gasket again or fipg? Someone mentioned fipg instead of the gasket but I can't remember if it was a reliable source.
Stumpalama
Forum Junkie
NOVA
Factory FIPG? HAHAHA, not on a 40 diff.
To answer your question, I used The Right Stuff.
OTRAMM
Supporting Vendor
Warrenton, VA
I doubt you'll find the yellow marking compound locally. You can probably get Prussian Blue at Napa which would work but is harder to read. I probably have a tube of yellow I can send home with you. I don't use the ones that come in the install kits anymore. I switched to using GM's marking compound. You can get it on Amazon. Make sure you clean around the studs really well. We usually pull them to make sure the entire flange surface is clean.
iptman
Northern VA
After much consternation I picked up some Right Stuff grey for the diff assembly. I was going back and forth between the Ultra Grey and the Right Stuff grey. I finally found an old youtube video from Permatex where they clearly state the Right Stuff FIPG is "best" and Ultra X is "better" so that's what I got.
I assume when I tighten the nuts I'm doing it in a cris-cross pattern and maybe even a 2 stage torque, maybe 20 then the final 34?
