Ok... doing some research on here and learning. Posted up earlier about the starter issue and the starter solenoid wire being completely gunked up so plan on replacing that.
Can anyone give a recommendation on where to find that replacement wire? It seems that part number has been discontinued by toyota, but don't want to throw just anything in there and it crap out in 6 months.
Also... in the research read a lot on the neutral start switch and I'm thinking that might be of legitimate reason for my issue. came across a form showing a guy cleaning it so will attempt that.
What kind of grease do you use inside that housing?
Also i found that there is a black and white wire going in powering the switch and then a black and red wire relaying to the starter. Crawling under her mine look different so not sure if someone altered it before me or if I am looking at the wrong thing. So my question is are these the wires and how do I go about checking them?
Thanks in advance... much appreciated
