I put in a dual battery system in my 200 with an isolator. Had the same isolator in my 80 and it worked great. My starting battery is an optima yellowtop, accessory battery is a red top. Anyhow on my main starting battery I’m getting tons of corrosion on the negative terminal. I’ve cleaned it multiple times. Used the felt pads, dialectic grease, etc.. this last time I soaked all the connectors and bolts in baking soda water and is dissolved all corrosion away so everything looked brand new. Now a week or two later it looks as bad as ever.
Any thoughts?
Do I need to replace negative cable?
I read that negative terminal is a sign of undercharging. I do a lot of short trips in the cruiser, but have a hard time thinking this much corrosion could build up in a few weeks?
Any thoughts?
