Negative switching to positive switching conversion.
MilkyWay
Im looking at getting some LED's and need to make the wiring for my headlights go from "negative switching" to "positive switching".
I want to use the stock switch (on/off -- low/high beams) to work with it...
Anybody has good info that explains this on layman's terms I would really appriciate it...
Does anybody sell a harness that can be incorporated into the stock H4 plugs to make this a simple thing ?
you're going to need to add a relay and a power circuit from the battery to the new headlight relay. you can use your stock headlight harness to switch the relays on or off- you;ll need 2 relays, one for LB and one for high...
