Wanted Needle/haystack, but if you've got a bad 60 driver's door...
dnp
Supporting Vendor
Jackson, MS
I need the front window track for my '85 FJ60's driver's door. This is the track that is bolted in the inside of the door and into which the front of the window slides when the window is rolled down. This is NOT the channel that is visible on the top of the door. When the window is rolled down, the front (leading edge) of the window will be held in place by this track / channel.
Again, I know that most don't want to part a front door to remove this piece; however, if you have an unusable front door in which this piece is not damaged, I could use it if you have one.
Thanks.
I probably have what you need. I'll check today
Let me know if you still need this
