NEED T-CASE help for 1994 FZJ80
need to find a t-case for a 1994 fzj80...this one is totally shot, any ideas or places to check out??
Lots of places, post in the wanted section, look up IRBIS and PM him, call cruiserparts net. look in the partuing out section, look in the main classified, thought I saw one there
TCs don't go bad on these - what's up???
DougM
this cruiser is a friend of mine's....clunking sound when shifting, hard clunk (metal on metal sound) and it does need a u-joint too.
4 wheel drive is not engaging at all...the mechanic did not open up the case, due to his experience with his driving diagnosis, in his own words...and this toyota tech does my work for me, currently putting in a new engine for me right now (all electrical equipment is operating, so it is not that)...asked him if it was the VC and said it could be but based on labor hours and parts and total cost, it would be cheaper to replace than to repair
Get a second opinion.
-Spike
this is the second opinion...her first mechanic said it was the tranny this mechanic only works on toyota and he has never had a misdiagnosis on mine
Four wheel drive never disengages, so saying that it doesn't engage makes me wonder. If the VC isnt working it can be removed cheaply, and isn't required. Its desireability is up to the owner. The LC is a very different animal from most Toyota products, so a Toyota mechanic could be just as lost as any other mechanic. You would be smart to find someone versed in LC's to check it out.
-Spike
Sure sounds like *way* more diagnosing need to be done before pulling the trigger on a specific "repair".
If you have access to the vehicle, why don't you drive it, check it out, and tell us much more specifically what's going on.
Curtis
P.S. Like Spike said, "4wd won't engage" doesn't really make any sense on an all wheel drive vehicle. Do you mean the shifter can't be moved/forced into Lo, or...?
Sounds to me like a broken front birfield. What specifically is the symptom? If its a 92 or older, then it's a stripped front drive plate (about an hour repair and $30...). This *might* happen on a 94 also. So, I'm telling you and others here are telling you it is NOT the transfer case and your friend is about to get hosed.
DougM
Gosh this looks a lot like a Tech thread. :hhmm:
-Spike
Then you need a 3rd opinion. As Spike, Curtis, and Doug have pointed out, this does not sound like a transfer case problem. It *might* be a transfer case but you have several things that need to be eliminated first.
Based on the very limited information you have given us, it sounds like Doug's theory about the busted flange or birfield. Those would both make a lot of metallic noise and the truck would "behave" strangely to a novice. The main thing they would notice is that it would move but it would move erratically and sometimes would lurch. This is caused by the VC trying to match front and rear outputs.
Please drive the vehicle and post more details. A few minutes here could save your friend several thousand $$$.
-B-
I remember the last thread we had about someone needing a new TC- I believe he had it replaced only to find out that the replacement was also 'broken', replaced it again, and I don't even remember what eventually happened.
-Spike
I'd say the TC is about the last thing that will break on the drivetrain, so unless this truck's been heavily wheeled with oversize tires and has worn out several sets of birfs and axles the TC is not the problem. I think we've made that point here, eh?
DougM
I realize that this is a pretty technical wanted ad, but the guy posted it in wanted because he wanted a transfer case. Moving it to tech might not help him get the transfer case if he still wants one.
Although a very well designed machine and 80s aren't known for TC failure, it could have happened. What if it was run dry? I'm sure that could cause problems. Or what if it was submerged in salt water? What if it really is toast.
Actually it started in tech and a uber mod moved it to wanted and I had it moved back.
He can start a "wanted" thread over there whenever he wants. :meh:
Meanwhile, a bunch of us would sure like to know what really is the problem. And yes, of course it could be the T-case after all; hopefully we'll find out one way or the other.
Curtis
I was wondering about you. Way to shift the blame to a place I can't reach. :D
-Spike (and thanks)
