Yes, fluid will leak out. Besides, you don't want to be trying to rebuild a caliper awkwardly, with it still attached to the vehicle. Getting the rubber piston boot seated is hard enough on a workbench.
I was thinking of doing the caliper rebuild while the brake hose was still connected, is this wrong ? When I push the piston out will brake fluid leak if I dont disconnect the hose and then plug the tip?
One additional step that will help minimize the amount of bleeding needed is to fill the caliper on the bench before you hook it up to the brake line. The easiest way to do this is to turn the caliper on its side so the brake line connection is up, fill to the brim of its opening, then quickly get the honse back in place. Assuming the golf tee holds back drainage from the brake lines, the filled caliper will help speed the process along.Remove the caliper, plug the line with a golf tee to stop the fluid from all draining out. Rebuild on your bench, reinstall and bleed the system. You don't need to flush it if it was done recently, just add more fluid at the reservoir and bleed each corner.
Or you could just follow the process in the FSM.One additional step that will help minimize the amount of bleeding needed is to fill the caliper on the bench before you hook it up to the brake line. The easiest way to do this is to turn the caliper on its side so the brake line connection is up, fill to the brim of its opening, then quickly get the honse back in place. Assuming the golf tee holds back drainage from the brake lines, the filled caliper will help speed the process along.
Between ordinary brake service and fiddling with the LSPV, a number of people have expressed frustration with getting the rear brakes fully bled, even when following the FSM. I wasn't suggesting skipping over that, merely suggesting that you'll limit the need for bleeding by minimizing the amount of air that is introduced in the process.
Piston looks ok. Here is the caliper and piston cleaned up.
Next:
1. Install new brake shoes.....Check
2. Rebuild caliper with toyota kit....Check
2. Install new brake pads.....Check
3. Fill caliper with brake fluid then install caliper (should I worry that brake fluid might leak onto pads as I'm attaching the caliper?)...No there is no reason to do this. The brake bleeding procedure (especially considering the LSPV) insures you will fill the calipers just trying to get the air out. You'll only create a mess for yourself if you pre-fill.
4. Install new rotors....No, you must install the rotors BEFORE the calipers.
5. Repeat on the 2nd rear tire.....Opposite side of axle.
6. Then bleed only the rear tires? Or all 4?...Do all four, you are already there.
Looks rust pitted to me. They're cheap enough that it's not worth putting an imperfect one back, IMO.
I agree with this for the most part. However, two things to consider. 1) is it actually rust pitted or just has some really tough residue on it? Mine had little places I thought were rust but after some vigorous scrubbing they came off. 2) if the chrome is chipped, where is it chipped and how badly. Out of all 10 of the pistons on my truck, only one actually was chipped. It was missing a tiny flake of chrome on the bottom of the fluid side of the piston, so near the deepest part that's inserted into the caliper. I elected to put it back in because I was half way through my brake rebuild and I didn't want to wait on new pistons. Under the circumstances I'm not worried about it because the only way the system could possibly stick or leak is if a chipped area interacted with the piston seal as the brakes were being exercised. That's impossible if the chipped area is that far back on the piston wall. You'd pop the piston out of the caliper before it traveled far enough to be a problem. So just think about how the system works and you can reason your way through whether parts need replacement or not. I'm not saying new ones wouldn't be a good idea, just that the answer is not always "replace everything".Looks rust pitted to me. They're cheap enough that it's not worth putting an imperfect one back, IMO.
