Need source 4 throw out bearing 4 1981 BJ44 w/ 2B-3B conversion (3 Viewers)
Rockaway Beach, NY; but was 14yrs in Saskatoon, CA
I have a RHD 1981 BJ44 which I am converting to a 3B from a 2B.
I stopped driving it as the throw out bearing started screaming something awful.
Is there a source for throw out bearings?
Good news is... the 3B had power steering. I have a LHD assembly for the frame, but the pump for the engine should work L or RHD...
So I guess I need a source for the RHD frame mounted power steering box/bits.
Best,
T
Tobash,
The 2B throw out is the same as the 3B. Also, if you are interested in putting PS on your 44, I'd do the 60/80 series box upgrade. you can get RHD boxes for those rigs so much easier than a RHD 40 series. Also, it gets rid of the push pull steering (no more center arm - Whoo Hooo!) which gets rid of a lot of places for slop to develop. I will have mine ready to go for next summer!.
Can you post up some pics on the 80 P/S when you have installed ...very interested.
X2 on the 3B throw out bearing be carefull when ordering since they seem to differ over the years and models
This is why I was hoping for a source.
Best and thanks so far...
Tobash
I eventually need to convert the vehicle to LHD, so right now I would rather just get the RHD unit from a RHD 40 series, knowing that in two to three years I can do the LHD conversion from a 60/80 series as an ultimate goal.
By staying with stock stuff in the short run, it means an easier installation and faster return to service until I do the full frame off restoration with conversiont to LHD.
Any sources you know of for the power RHD unit or a reasonable option for replacement?
Thanks very much,
T
Part number Toyota
90363-45001 for both 44 model with 2B and 42 model with 3B
1982 BJ60 used 45001 then changed to 45002
BJ7* with 3B used 45002
